Click the links below to view examples of case studies associated with this category. Remember, you can add your own case study with this form.
Case Studies:
- 2001-01 Utilizing IIoT Technology to Identify Process & Energy Improvements in the Foundry
- 2001-02 Foundry Powered by Xcel Solar Garden
- 2002-01 Cupola Blast Air Dehumidification System
- 2002-02 Carbon Capture and Conversion to Biomass by Fast-Growing Cyanobacteria Cultivated on Wastewater
- 2002-03 ISO 50001 Energy Management Certification – First Metalcaster in US
- 2002-04 Green Sand as Road Base - Beneficial Use
- 2005-01 Foundry Sand Beneficial Reuse in Cement Manufacture
- 2005-02 Six Sigma PM (Particulate Matter) Emission Reduction
- 2005-03 Process Automation Improves Safety & Reduces Environmental Impact
- 2006-01 Closed Loop Cooling Water System for Process Cooling and Casting Quench
- 2007-01 Non-hazardous Waste - Ferrous Melting Baghouse Media
- 2105-01 Centrifuge Upgrade Reduces Alcohol Consumption
- 2105-02 Multi-Master Air Compressor Controls
- 2105-03 Stormwater Infiltration System
- 2105-04 Rube Goldberg Dream Machine - Metal Reclamation
- 2105-05 Core Oven Replacement–Higher Efficiency, Lower Emissions
- 2105-06 Green Construction of Administration Building
- 2105-07 Dust Collector Exhaust Recirculation Inside - Return Air Heat Harvesting
- 2105-08 Comprehensive Air Compressor Sequencing Control
- 2105-09 Comprehensive Lighting Efficiency Upgrades
- 2105-10 Sprue Crusher – Energy Savings
- 2105-11 Sand Conditioner Upgrade
- 2105-12 Air Compressor Heat Harvesting
- 2105-13 Dust Collector Variable Frequency Drives & Controls
- 2105-14 Membrane Filtration Conversion for Dust Collection
- 2105-15 Sustainable Forest Study
- 2105-16 Dust Collector Replacement-Upgrade
- 2105-17 Monarch Butterfly Sanctuary
- 2205-01 Reclaim Spent Green Sand for Coremaking
- 2205-02 Smart Exhaust Fans
- 2205-03 Employee Volunteer Emergency Response Team
- 2205-04 Goal Recycle or Beneficial Use of All Waste Streams
2306-01 Corporate Sustainability Reporting – Stakeholder Communications Best Practice
