AFS directly funds research projects from the allocation of a portion of annual dues paid by AFS Corporate Membership. Current AFS-funded research projects are described below.
Updated March 2024
19-20#02 Effect of Ceramic Sand on Cast Iron Mechanical Properties
Principal Investigators: Dr. Scott Giese, University of Northern Iowa
Steering Committee Chair: Brandon Reneau, Caterpillar
Due to the OSHA Silica Rule under enforcement in the foundry industry today, many foundries are considering changing from silica sand to a ceramic sand/media to alleviate the issue. Many questions are associated with this change, but one that is of primary importance is understanding the effect, if any, in microstructure and the associated mechanical properties that might accompany the use of the ceramic sand/media.
The purpose of this project is to evaluate the effect of ceramic sand/media on the mechanical properties for Class 30 iron and 80-55-06 ductile iron.
The project is being monitored by the AFS Cast Iron Division. For more information about the project, contact AFS Director of Technical Metalcasting Services Travis Frush (tfrush@afsinc.org).
20-21#02 Quantifying Aluminum Casting Quality Through H Gas - (Phase 2)
Principal Investigators: Daniel Hoefert, Eck Industries, Inc.
Steering Committee Chair: Adam Kopper, Mercury Marine
Foundries producing gravity pour aluminum castings have several gating concepts to choose from. Phase 1 (Quantifying Casting Quality Through Filling Conditions) compared three systems that provided different filling conditions ranging from tranquil bottom filling to semi-tranquil side filling to turbulent top filling. The results of the top and side filling gating systems repeatedly exhibited less shrinkage porosity and improved the general tensile properties over the bottom filling system. While bottom filling did avoid turbulence and oxide films associated with buoyant bubbles and non-buoyant flow tubes. Tranquil filling did not reduce the overall shrinkage porosity in the castings and did not improve tensile properties. However, other observations suggested that a relationship may exist between hydrogen gas levels in melts and subsequent interdendritic porosity. It also suggested hydrogen gas levels may reduce bubble formations.
The purpose of this project is to gain additional understanding regarding the solidification and filling dynamics that common defects are associated with, such as porosity (micro and macro), bubbles, flow tubes, and hydrogen gas.
The project is being monitored by the AFS Aluminum and Light Metals Division. For more information about the project, contact AFS Vice President of Metalcasting Technical Services (bbegan@afsinc.org).
20-21#06 Machinability of Solution Strengthend Ferritic Ductile Iron
Principal Investigators: Dave Labyak and Paul Sanders, Michigan Technological University
Steering Committee Chair: Mark Osborne, Wabtec
Lack of machining knowledge has impeded the growth of solution strengthened ferritic ductile iron (SSFDI) in North American markets due to machining shops using machining costs associated with conventional ductile iron grades.
The purpose of this project is to understand the machinability of SSFDI grades compared to conventional grades to help expand the market for SSFDI grades.
21-22#03 Multi-axial Measurement of Casting Wall Movement During SGI Solidification and Cooling in In-Molding
Principal Investigators: Dr. Mingzhi Xu, Georgia Southern University; Dr. Simon Lekakh, Missouri University of Science and Technology
Steering Committee Chair: Jiten Shah, PDA LLC
Casting wall movement during metal solidification and cooling causes external surface distortion on complex ductile iron castings. Casting wall movement is also related to internal porosity formation within the castings.
The purpose of this project is to develop an experimental apparatus to perform multi-axial measurement of casting wall movement during ductile iron solidification and cooling. A full set of variables will be systematically studied, including mold strength, pouring temperature, riser condition, metalhead pressure, CE, nodularity, and inoculation.
22-23#01 Refining Austenite in Gray Irons
Principal Investigators: Jingjing Qing, Georgia Southern University
Steering Committee Chair: Leonard Winardi, Charlotte Pipe
It’s well known that the properties of cast iron are related to the fineness of the microstructure features, such as graphite particle size, eutectic cell (GI) size, and pearlite lamellar spacing. Good attentions were paid onto refining sizes and distributions of graphite (nodule, flake and compacted) via inoculations, or refining pearlite structures using alloy additions, but much less effort was put into the study of refining austenite in cast irons, especially evaluating the effects of inoculant on austenite grain size.
The purpose of this project is to study the effects of different types of inoculants on the austenite grain size and mechanical properties of the differently inoculated cast irons. Heterogeneous nucleation to refine austenite in cast irons will also be explored.
22-23#04 Biobased Polymer Foam Pattern for Lost Foam Casting
Principal Investigators: Jacob Belke, Mercury Marine
Steering Committee Chair: Marshall Miller, 3D Systems
Lost foam patterns are made of expanded polystyrene (EPS) which is derived from crude oil. The negative environmental impact of the oil and gas industry has been well documented and is not sustainable.
The purpose of this project is to identify an environmentally sustainable biopolymer(s) that can become an alternative to the current petroleum-derived polystyrene.
The project is being monitored by the AFS Lost Foam Division. For more information about the project, contact AFS Senior Technical Associate Bo Wallace (bwallace@afsinc.org).
22-23#06 Understanding and Mitigating the Effect of Boron in Ductile Iron
Principal Investigators: Laura Bartlett, University of Missouri Science & Technology
Steering Committee Chair: Kramer Pursell, Metal Technologies Inc.
Boron has shown to cause multiple effects on microstructure and mechanical properties of ductile iron castings, causing an increase in problems for ductile iron foundries.
The purpose of this project is to quantitatively evaluate the effect of different boron additions in the range of 8 to 60 ppm on the microstructure and mechanical properties of pearlitic and ferritic ductile irons.
